Restauro borchiette  FPS  Icon_minitimeMar 23 Apr 2024 - 15:10 Da Tabella
Restauro borchiette  FPS  Icon_minitimeVen 12 Apr 2024 - 8:00 Da Timo
Restauro borchiette  FPS  Icon_minitimeGio 4 Apr 2024 - 1:24 Da Cleo Amedeo
Restauro borchiette  FPS  Icon_minitimeMer 3 Apr 2024 - 12:56 Da luciano parisi
Restauro borchiette  FPS  Icon_minitimeMar 2 Apr 2024 - 12:21 Da franatoinsafari
Restauro borchiette  FPS  Icon_minitimeGio 21 Mar 2024 - 17:15 Da Lucas1976
Restauro borchiette  FPS  Icon_minitimeDom 17 Mar 2024 - 17:58 Da ottogalli156
Restauro borchiette  FPS  Icon_minitimeMer 13 Mar 2024 - 15:04 Da Davide66
Restauro borchiette  FPS  Icon_minitimeDom 10 Mar 2024 - 20:14 Da ottogalli156
Restauro borchiette  FPS  Icon_minitimeMer 28 Feb 2024 - 14:49 Da willy
Restauro borchiette  FPS  Icon_minitimeVen 2 Feb 2024 - 18:34 Da Andrea500
Restauro borchiette  FPS  Icon_minitimeLun 22 Gen 2024 - 20:39 Da emying
Restauro borchiette  FPS  Icon_minitimeMer 17 Gen 2024 - 17:25 Da luciano parisi
Restauro borchiette  FPS  Icon_minitimeVen 12 Gen 2024 - 17:45 Da lucadoc
Restauro borchiette  FPS  Icon_minitimeVen 12 Gen 2024 - 10:39 Da francescobud
Restauro borchiette  FPS  Icon_minitimeGio 4 Gen 2024 - 8:39 Da Lucas1976
Restauro borchiette  FPS  Icon_minitimeSab 23 Dic 2023 - 12:54 Da bisonale
Restauro borchiette  FPS  Icon_minitimeDom 17 Dic 2023 - 10:16 Da alefulvia3
Restauro borchiette  FPS  Icon_minitimeMer 6 Dic 2023 - 8:35 Da Andrea500
Restauro borchiette  FPS  Icon_minitimeMar 21 Nov 2023 - 14:48 Da Maxpask22
Restauro borchiette  FPS  Icon_minitimeSab 18 Nov 2023 - 18:52 Da Andrea500
Restauro borchiette  FPS  Icon_minitimeMar 14 Nov 2023 - 21:26 Da franatoinsafari
Restauro borchiette  FPS  Icon_minitimeMar 14 Nov 2023 - 21:25 Da franatoinsafari
Restauro borchiette  FPS  Icon_minitimeVen 27 Ott 2023 - 12:45 Da clakira
Restauro borchiette  FPS  Icon_minitimeGio 26 Ott 2023 - 15:34 Da Davide66
Restauro borchiette  FPS  Logo_c14
pressione candele fulvia sedili motore filtro ammortizzatori scarico accensione sterzo cruscotto colore gomme griglia cerchi pompa carburatori montecarlo benzina volante freni cambio fari olio radiatore Freno
3 partecipanti
Numero di messaggi : 3773
Restauro borchiette  FPS  Empty
MessaggioTitolo: Restauro borchiette FPS    Restauro borchiette  FPS  Icon_minitimeMer 30 Gen 2013 - 20:36
L'altro giorno mentre ero al lavoro e lucidavo dei fanali di una Ford Focus ho pensato.... Chissà se usando il medesimo procedimento per lucidare i fanali in plastica si riescono a pulire le famigerate borchiette FPS ormai ingiallite dal tempo e dall'usura...
Ne ho solo 3, per altro abbastanza bruttine, comprate per 50 cent l'una l'anno scorso alla fiera Automotoretro...
Ieri ne ho presa una, (preciso che erano tutte 3 ingiallite allo stesso modo) e a fine orario di lavoro ho provato a pulirla... Ecco il risultato confrontato con una borchietta ancora da pulire:
Restauro borchiette  FPS  Dscn0810
Stasera ho fatto anche le altre 2:
Restauro borchiette  FPS  Dscn0811
Il risultato è abbastanza soddisfacente, la "parte gialla in superficie è andata via completamente e sono rimaste belle lucide. Tuttavia guardandole con una certa angolazione si nota un ingiallimento residuo nella parte interna del vetrino... Se si riuscisse ad estrarlo e quindi lucidare anche dall'interno sarebbe veramente il massimo ma dubito sia possibile senza fare danni Sad
Qualcuno ha mai provato a smontarle o ha qualche idea in merito? Sicuramente il vetrino è stato messo dopo...
Numero di messaggi : 1503
MessaggioTitolo: Re: Restauro borchiette FPS    Restauro borchiette  FPS  Icon_minitimeVen 23 Ago 2013 - 10:16
Leggo solo ora questa discussione. Il vetrino in plexigas veniva messo ad incastro sulla coppetta e il bordino nero intorno al vetrino garantisce la tenuta. Ne ho provati alcuni a smontare ma bisogna scaldarli per bene in quanto, essendo plastica di circa 40 anni, le rotture o lesioni sono sempre in aguato.
Io ti sconsiglio di smontarli perché rischieresti di rovinarli......
Numero di messaggi : 2395
MessaggioTitolo: Re: Restauro borchiette FPS    Restauro borchiette  FPS  Icon_minitimeLun 26 Ago 2013 - 11:39
Uau, perfetto direi! O comunque molto molto soddisfacente il risultato.
Posso chiederti come hai operato ? Io ho preso un polish alla Beps per lucidare i vetrini strumenti del 128 ma risultato pari a zero per cui sono in fase di rifacimento ...
MessaggioTitolo: Re: Restauro borchiette FPS    Restauro borchiette  FPS  Icon_minitimeLun 26 Ago 2013 - 12:27
Posso dare piccolo consiglio?
Seppiare con acqua e sapone con carta 800, 1000, 1200, 1500.A questo punto si possono usare i polish della 3M: come primo prodotto il ravvivante di colore bianco, poi il polish da rifinitura fine di colore rosa e in conclusione il Protettivo al silicone.
MessaggioTitolo: Re: Restauro borchiette FPS    Restauro borchiette  FPS  Icon_minitimeMar 27 Ago 2013 - 18:44
Io ho operato così:
- Pulito bene il vetrino con acqua
- A vetro ben bagnato d'acqua ho passato carta vetro 1200. Bisogna insistere abbastanza, proporzionalmente all'ingiallimento del vetro. Ti sembrerà di rigarlo, invece seppiandolo asporti un leggerissimo strato di materiale (quello ingiallito appunto). Molto importante è che il vetrino sia bagnato!!!
- Ripulito il vetrino e lucidato prima con il polish apposta della Wurth e poi con quello di rifinitura. Penso comunque che un qualunque polish possa dare un buon risultato...
Per lucidare ho usato un dischetto apposito da attaccare al trapano...
MessaggioTitolo: Re: Restauro borchiette FPS    Restauro borchiette  FPS  Icon_minitimeMar 27 Ago 2013 - 19:30
Andrea500 ha scritto:
Io ho operato così:
Per lucidare consiglio il disco in puro cotone d' agnello a più strati sovrapposti....costa un pò (sui 50 Euro) ma è in assoluto il migliore Razz .
Comunque, a quanto vedo, i nostri metodi non sono così tanto differenti....
» Restauro carrozzeria
» Inizio restauro Montecarlo
» restauro vs acquisto restaurata
» Fanalone, Fanalino, 1.3 hf in restauro..!!
» Restauro non impegnativo
